Zach Scherf
I installed a few new parts in my 2-150 in the three speed last
year and split again a few days ago to address some leaks. It
is leaking the ATF from the circle looking housing which has a
line going into it on the rear end of the three speed. If memory
serves me right there is an o ring in there that is about 6"
around. That o ring I ordered from agco and it seemed to big
from the beginning and I had a hard time getting it to seat in
there before I bolted it all back together. I imagine that is what
is wrong as far as that leak. I plan on getting it apart and
ordering a o ring that is smaller so it goes together easier. Has
anyone else had that problem with that o ring not dealing or
fitting together well? Also I had ATF leaking into the rear end I
think. I don't think it was hydraulic fluid. I noticed it one day
when the floorboards started to get a little warm so I parked it
and checked the rear end fluid via the plug near the pto and it
was overfull and seemed red. What seal should I check out for
that to happen?
Thanks
I hope I gave enough info for someone to get me on the right
track!
that to happen?
Thanks
track!
