WFE270NWIA
Ran the 1755 out of the shop, and was going to leave it run a wile to charge the battery. Came back after about 20-25 minutes. It was smoking a lite blue real bad. had a cloud going through the grove. Checked the oil and had 1.5-2 gallons antifreeze in the crankcase. Dropped the pan and filled radiator and looked for leaks found nothing. Pumped the system up to 7 psi still nothing. Put cardboard under engine. 12 hours later no antifreeze on cardboard and system was still holding pressure. There was maybe 2 drops hanging on no. 6 sleeve. I'm thinking something that opens up when it warms up? Anything more I should check before I tear into it. Was hoping I could figure out what was leaking before I took it apart. Thanks.
