Jake Collie
My wide front axle carrier is all wobbled out on the front side where the pivot pin goes through. I need to either replace it or get it bored and sleeved. Sitting here at work, away from my book I am wondering, Can I jack up the tub, remove the pivot pin, and unbolt the carrier without removing anything else from the axle? The AGCO parts book picture shows 4 bolts that will need to be removed to get the carrier off. It looks like the steering shaft goes through the carrier as well with a bushing and seal on the bottom side of the carrier. Will I be able to remove the 4 cap screws and roll the carrier off the shaft and around the axle to remove it?
