Belt pulley for Oliver 70
Dalex
I have two of these and I saw a pic of the pulley assembly on EBAY .... how is the pulley driven ? I don't see anything on mine that would connect to it .
There is a sleeve about 4 inches long with internal splines. It slides over the splines on the pulley and the splines on the tractor belt pulley unit.
I guess I wasn't clear , this would be the belt pulley on the right side next to the operators foot.
if you need a pulley I have one I would like to sell and could send pictures if interested. located in western Minnesota but will ship also. email should be open
The belt pulley is driven by a splined shaft that is driven by the power lift( dome shaped cover that the gear shift lever is mounted into.)The power take off, power lift arms and belt pulley all are engaged by the round handle that is on the right side of the power lift dome.
Travis sent me an exploded view of the trans front cover where the pulley drive goes , and neither of mine have it , I just have the basic cover that supports the steering box , That's why it was so confusing. Thanks guys ....
