oliver 77 drive line parts?
showdown
I need a new shaft that goes from the flywheel,and coupler, and input shaft from coupler into trans, where can I buy these?
One thing you need to remember the shaft that goes into the clutch is different from the early models to the late models. You need the late shaft if you have a ball bearing type pilot bearing and the early one if you have a bushing for a pilot bearing.
mine is a 1954 it has a brg. in the flywheel. The ones I saw on walt"s tractor for the 77 doesn't look like mine . The one they show for the 66 looks like mine. I will have to call them tomorrow to see what they say.
