mr.precision
Had the radiator out to replace the water pump, hoses, front crank seal, and a few other items. Tractor didn't run for about 6 weeks. Got is all back together, and the motor now runs rough at fast idle. It "coughs" followed by a poof of blue smoke. Stuck valve? Broken ring? I can't understand why this started after sitting for a while, although these things happen when you work on something 70 years old.
Will pull off the valve cover and set the valves to 0.015" and see if that helps.
Any other ideas?
Any other ideas?
