what is my White Mighty-Hoe
cpayne
New User
Could someone please help. I have a White or Oliver or White-Oliver Mighty-Hoe with a 1617 backhoe. I need a operator's manual and informtion on what the tractor is and how old. I have the numbers or part of the numbers.
Well what do you have for numbers for the tractor. If it has a loader you will need manuals for all 3 components. You have e-mail or phone number? J.
The Model number is 565-92010 and the number near the alternator starts with 1874..and is rusted from there. I have a service manual for a 1650 1655 2-70 and a manual for the 1617 backhoe. However, I need to know what oils to put into the transmission and what filters. Thanks for the quick response.
The number "565" indicates it is a 1655. In the next five digits, the "9" shows it is industrial. And the "2" makes it a diesel.
The tractor would use the same oils as a 1655.I use universal hydraulic oil in the loader.
Mine has the 1615 hoe and the 1678 loader. My serial number shows it is a 1650.
I don't know why my email is not showing. [email protected]
I need to know what oil to put in clutch? section of the transmission and the transmision, and filter numbers. If someone has a operator/owners manual, I would be greatful.
(quoted from post at 04:31:25 01/23/15) The number "565" indicates it is a 1655. In the next five digits, the "9" shows it is industrial. And the "2" makes it a diesel.
Great info. What horsepower? and do I treat it more like a White or more like an Oliver? Also, the 1617 is crazy heavy in the back. Here in the hills of Kentucky I have to drive it using the back breaks to steer while the front end is not on the ground.
If it is front wheel assist:backing straight and I mean straight
up hill will give you way more traction and control
