young tractor
Ok guys,
I got the governor set up to your directions and the books. It now idles down like it should. I never could get it to do that. When at idle the governor doesn't surge, but when at wide open it really surges. The book says how to set the bumper, but mine is already screwed all the way in. I backed it out a ways and it did nothing. My gut says the bumper spring is missing and that is probably why someone had the linkages all messed up. Would you agree? Can I put in a new spring in from the outside and thread the bumper screw in with the spring on the end or do I need to take the governor off to do it? Also you guys recommend that I replace the thrust washer. I have a parts book that shows there are 2 thrust washers: One behind the gear and one up front by the fork. Are you guys talking about both or just the one behind the gear? The book also calls the part next to the front thrust washer a thrust bearing. Do I replace that too? Thanks again for all of your help. This is on a 1948 Old style 88 standard.
