Leaky injection pump?
Have a 2-70 with a leaky injection pump. Shut off the sediment, it stops. But it does leak while running. I had someone who told me to get the seal kit and they would do it. But, now I can't get them to commit to a time they are so busy. Has anyone ever replaced the seals before and if so, what kind of a deal? Any suggestions? Thanks, Brad
Where does it leak? Externally there are not too many seals? Does it leak by the governor cover or the throttle shaft? Need more details. J.
While some leaks can be fixed on engine, resealing the complete pump is best. Have seen too many times other leaks show up later after a patch job was done.
