1850 build card question
I received my build card the other day and I have a
question on my code "Q" clutch, aux trans number. My
"Q" number is 434 which corresponds to "Sparky's 1850
hi crop". I definitely don't have a hi crop so what
does Sparky's 1850 hi crop mean when it comes to letter
Q?
   The "Q" column on a build card is the clutch / auxiliary unit (if equipped).   434 code is: 1850 Dsl, equipped w/button clutch and over/under hydraul shift.   The tractors will be the same except rear axle "R" and "P" hitch.   Most will had rice tires (tire code R2 either followed by O for open tread or C for closed center tread.
   All tractors will have a clutch and most a aux trans either row crop or hi crop, thus "Q" code has nothing to do distinguish between them.
Thanks very much for the information! The sheet they sent me with the build card doesn't say anything about a button clutch. Maybe they sent me the wrong sheet. It literally says "Sparky's 1850 Hi Crop" after Q 434. I do have the button clutch with the over/under trans. I also have code 47 rear tires code O62 hitch and code72 rear axle.
