Early OC4 grille?
I am working on an early OC4 with the 4 cylinder engine and the grille that should look like a fleetline. Grille is gone and has a mangled OC3 grill bolted on. I would like to find the right grille for it. Zimmermans does not have one, but recommended using the newer grille which will apparently bolt on. Is it the same as any wheel tractors? Close enough to a wheel tractor that I could use available pieces to build one? Where else could I try for a used one? Thanks for any help,
Josh
The grille halves were the same as a 66 or 77. I don't know about the whole piece that held the radiator.
