1850 valve cover gasket
I have a leaky valve cover gasket (Perkins diesel) so I ordered a new gasket from AGCO. The new gasket is a cork like material. From what I have read on here the newer gaskets should be made from a rubber substance instead of cork. The AGCO # is 4222942V1 for the cork gasket I bought. Does anyone have the part # for the rubber gasket? Thanks.
First of all on an 1850 you can have a cast iron or a stamped steel valve cover gasket. Needless to say the two covers each take a different gasket. So tell us what cover you have. J.
