oliver 2255 MFWD ,over under and transmission questions
Farming1974
New User
Good morning,
I bought a oliver 2255 mfwd to hobby farm with and restore. I know the over under needs some work as the rear seal is leaking into transmission. I also notice the trans is hard to shift. During some of my research I found that the white over under units where updated and built stronger .
First question is would I be better off putting a newer type over under and transmission in?
I was thinking perhaps from a white 2- 180 series?, if so does anyone know what modifications would need to be done?
Does anyone know how well the 2255 overunders and transmissions hold up?
Slide over to the Moline site and read about the questions on the G-1355 which in simple terms is the same tractor as a 2255 from the clutch back.
