mr.precision
Put a new water pump on the 1946 Standard today, and noticed a large chunk missing from the crank pulley. It is also bent. I suspect someone tried to remove it with a hub puller at some time in the tractor's life.
How do you get the thing off? My factory shop manual says nothing more than "remove pulley". Is the nut where the hand crank catches welded in, or does it function as a nut to retain the pulley? Anyone have a good pulley for sale?
Thanks
Thanks
