cockshutt 40 motor what motor is this????
olivers66
looking on info on motor in my cockshutt 40 2 casting #on block b563 and b1871 what motor wood this be any infor wood be great
I live in central indiana. I bought the tractor and did not know anything about the engine, the plugs were out of it and the valve cover was loose, so I pulled the pan and head to check it out. The head is rebuilt new rings, crank has been ground I guess they never adjusted the valves and fired it about all they had left to do. It needs a head gasket and a couple other gaskets cleaned up and should be ready to go, I can do that or sell it as is.
