Ohio88
- Location
- Fairborn, Ohio
We have a Super 88 Diesel to rebuild. While we are at it we are thinking of larger valves, 1800 piston and sleeves and a rosa-master injection system, we plan to a a groove for the second o-ring on the sleeve. This tractor is used.
The first question is do the sleeves have to be shortened. If some one has done this does the cooling system work well?
Will the pistons work with the 88 indirect injection?
What would a good valve set be for larger valves or do we need to look for a different head.
What kind of power could we expect?
