oliver1755
I have a 1964 1650, SN 151274. It has a single speed PTO, 540 RPM. It has been leaking rather significantly at the PTO shaft. The other day, I went ahead and popped the snap ring out and pulled the shaft out. I can see into the transmission through the hole.
I put the shaft back in and wiped the outside down. It looks like it is leaking through the bearing and maybe around it. I know there is an o-ring in there that the outside of the bearing would seal against.
Is the bearing supposed to be holding the oil back or is the expansion plug missing that I see in the parts book, therefore not keeping the oil out. I couldn't quite tell for sure if something was missing from the parts book.
Thoughts appreciated!
