Oliver 1355 Engine
JDSNOW
Just throwing this out there. I bought a oliver 1355 fiat style that is a little rough and the engine is shot. I plan on rebuilding it back to a farm tractor for myself. My question is does any one know of a used engine for it? I have done a handful of tractors like this. But this winter time is short and a good used engine could save me a lot of time. Any lead appreciated.
First off, if you have a 1355/1365 engine that is worn out, that tractor has a LOT of hours on it. I would hazzard a quess that about any motor you would find is also going to have a lot of hours on the thing. At least if you rebuild the one you have, you know what you've got.
JDsnow, i have a cockshutt 1355 with a fiat engine. not sure if it will work for you or if you have any interest but let me know. not sure where you are located but i am in maine.
Is there any major differences in the 1355 or 1365 engine? I also heard a rumor a 2-60 engine would bolt up. I have not taken the time to look into that rumor.
not 100% sure but i believe the later 1365 has little different engine(bit more horses too)210c.i.you can buy brand new short blocks or complete engines from importtractorparts.net they specialize in these little fiats very knowledgeable.
Actually there are two different engines that can be in the 1365 models but if you exchange the whole engine it doesn't matter it'll work and so will the 1355 and the 2-60 White engine as I understand.
