66 Front wheel bearings
couldn't find them at a local parts store ( greyline) so I had to order them from Korves
<img src = "https://content-na.drive.amazonaws.com/cdproxy/templink/8nJka5eTN2OAyydEzNALCMsKjpHd6LyoxUhGFlTv2c4LAYspN?viewBox=1550">
<img src = "https://content-na.drive.amazonaws.com/cdproxy/templink/mHuNh7YcPsVrWxSwyrY-Ifja3d79tz2nBlCONocyJxQLAYspN?viewBox=1550">
Numbers are SKF/CR.
Timken Numbers 09067/09195 outer, the inter is 15123/15245. Serial numbers for a 66 Row crop start at 420 001. The only older Oliver rowcrop tractors with serial numbers starting with a 2 is the Model 70.
Be advised that there are different bearings depending on the serial number of the tractor. If you go to the Agco website you can look up the Agco numbers and usually a Google search will find alternate part numbers.
Rich
The 66 & 66 super model row crops take the same bearings. The 660 tractors take the other bearings. Right out of my 66, Super 66 & 660 parts book.
