Transmission gears 1600 to0 1650
weaser
Will the transmission gears out of a 1963 - 1600 industrial tractor fit in a 1965 row crop 1650 transmission?
The 1965 -1650 serial number is - 167410-452. I don't know the serial number or transmission number of the industrial 1600. I bought the gears over a year ago and the seller didn't keep the serial numbers but he insisted that was a 1963 industrial model. What is the critical point I need to know or should I just forget the 1600 and try to find another set of 1650 gears?
Hi John
I'm having trouble with my e-mail and I don't know if you received them or not. I can receive but sending is a problem. I'm looking at changing five gears, two on the upper shaft, two on the counter shaft and two on the pinion shaft. This should make it a high speed transmission. I know it's a lot of work, but it seems like a good challenge and a nice reward if it works right.
Thanks
