1946 Adams 311 TD-9 with Oliver EOA trainmission
Fatamus
Does anyone have information on EOA 35 transmission
Off this website at YT from a link in 2005 from two guys named old and Oliver fan
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=oliver&th=69638
Well I could not get the link to work but I know Old has or had a grader. There were 2 models of those units The OA 35 and the larger EOA 50. They were also found in Huber and Galion graders. Both those models were up dated and became the EOA 350 and EOA 500. The model 35 was a basic Oliver 80 standard final drive while the 90/99 four speed unit was the base for the 50 & 500 models. The township in the north end of the county has a grader with the 350. It is 1958 or later as it is powered by an H six cylinder like they used in the 4 & 560 tractors. I will send you an e-mail. If you look some of those castings will have casting numbers with a letter D prefix. I am surprised it is TD-9 instead of UD-9 for the power unit J.
