1550 oil cooler lines
Mike(NEOhio)
Location
Newbury, Ohio
I appreciate all the advice you all have given me since I got this Oliver. I have another request. Can someone post a pic of how the oil cooler lines are routed and connected to the head? This is what I have. The hoses are running down the side and outside the distributor(alternator wires, too). It looks cobbled together and the parts book doesn't show much detail.
The 2 long studs sticking out of the valve cover are for a dry air cleaner to bolt to it like on this 1550. I will look through my pictures and see if I have one of how the ones are run my 3 1550's and post it. Bandit
The 1550 gas has them run up and on top like you have them run. The 1550 Utility has them running down the side. I guess there is no one way to run them. Hope this helps. Bandit
