White 2-110 mfwd........Again
Hey guys and gals. Anybody know where I can find a pair of 12x24 wheels for the front of a 2-110 mfwd?? Good used ones, or even new....as long as they don't cost an arm and a leg. I'm assuming mfwd front wheels from a 2-105, 2-85, 2-88 etc. will all work.
So far, have tried Maibach's and All States with no luck.
Thanks
507-235-6638 ask for brad that's where I buy tires and rims they are usually very good on prices.
13.6X26's are only 1" larger rolling circumference than 14.9X24's. You rims could be narrowed up to 12". Also, make sure you check with your tire supplier to confirm rolling circumference on what they are selling you. I'm going off my Firestone info.
Thanks BM. I had actually already thought of this, but instead of cutting the rims down, I was thinking of using my 14" rims with the 13.9 tires. Correct me if I'm wrong, but, I'll be using tubes, and this would spread the tire out, and help shorten the rolling circumference. The only problem, I've run into, is finding tires. I'm wanting long bar, short bar on all 4 corners(best hillside tires that I've ever used). I can find them in the 14.9-24's, but so far, no luck in the 13.6-26.
World wheel and rim in St Ansgar, Ia 800 443 9653. They made some 28x12 heavy duty rims off set for 30" rows for my 1855. $429 each through NTS tire. I'm not sure if the 2-110 has the same axle tho. Changing wheel size is quite expensive on a MFWD. I went from 34" rubber to 38". Had 18.4-34 and 13.6-24.
Thanks for the number, Adam. Yeah, I'm going the opposite direction from what you did. I've got 20.8-38's matched to 16.9-26's, and changing to 18.4-34's and 14.9-24's. Fully agree with it being expensive to change.
If you 're not worried about them looking factory, I can make a set of flat plate rims, rather than the dished center that they originally had.
Actually, BM, I think the ones with the flat center look better. The wheels on the front of this 2-110 look.....I don't know...like they belong on a foreign tractor.
What would you charge to make me up a couple of rims?? Where are you located?? Any idea what it would cost to ship to 40353??
Thanks
