1550 core plugs in head
Mike(NEOhio)
Location
Newbury, Ohio
Does the 232 gas have any plugs under the valve cover? Two of the four on the left side seep a little and I don't want to take it off if there are no more under the cover. Parts book calls out brass plugs. Can I replace them with the plugs from parts store?
Look what's draining from the rear end.
No connection. I've been working on it a little at a time all summer. Keep finding more things wrong. Been running it with straight water, changing it to flush the cooling system. Some water seeped around the plugs in the head after setting overnight. Pulled the PTO clutch (it needs work, too) and dipped a wire into the rear end. Creamy whitish oil, so I pulled the plug to check for water. Just an unfortunate chain of events. I see four plugs in the head, just wanted to know if there are more under the valve cover.
