Bison2010
I have a frozen pin. Anyone know how to get it out
Use a pin pusher, like for anchor pins on big truck
brakes. That's what we used on the last one along
with heat and penetrating oil.
On ours I drilled and tapped a 1/2-13 hole in the
end, scewed a piece of good threaded rod in, slid a
piece of pipe over and jacked it out with a heavy nut
and thick washer... Of course heat was added at the
same time and it did spoil the pin, but it was out! I
work in a machine shop shop so I was able to easily
make a new one.. Good luck!
_ have removed a lot of them---When they are really tough,I heat it as it looks like you have & used a big Snap On air hammer with a punch---They will finally give up---Good luck
Kent
