1610 spacers?
Don-Wi
I'm mounting the leader on my 1600, and it almost looks like there should be some spacers between the frame and the tub, as with the center support in the front had to get pulled in and there is a bit of a gap on the back bolt.
Washers?
Donovan from Wisconsin
The 1610 loader I had put on my Super 88 back in the 70's had spacers, one on each side. 1/2 inch steel plates, 6 inches by 7.5 inches, drilled for four bolts. Still have my spacers in my scrap metal supply, just went out and measured.
Don,
I have a 1610 that I have used on a 1550 and 1655, should be the same frame width as your 1600. There is a spacer between the frame and the loader. I am not sure on width, I'll see if I can't remember to check it this evening. The loader hasn't been used in a few years, and it is sitting out back with the spacers wired to it so they don't get lost.
Josh
I just used a stack of washers for now, I'll make some plates later. After I had the loader all installed I found one of the spacer plates that was on the allis loader that was cobbled on our 1755.
That plate has what remains of a decal off a plow bottom side plate. Might just use that for one side. Maybe see if I can find the other one too. That'd be too simple though.
Don, I went and looked at my 1650 parts tractor with 1610 loader frame and it has three spacers on each side if you need them taken off for dimensions just holler. Greg
Don, took a couple pics this morning while feeding horses.
Never woulda guessed that there were that many in there. I just used 4 washers on each side and it seemed to make it fit alright with the center bracket and the arms.
On a positive note, we used it hard all weekend and only blew one really old looking hose.
