77 water pump
Eric-IA
I need to replace the water pump on my 77. The manual says the radiator needs to be removed. My question is can it be done without? Thanks.
Or you can try it without removing the radiator and put a hole in it like i did last winter. Yes I got it done but had to then take the radiator out and have it fixed. Take the radiator off and save yourself some time, trust me.
not sure if the clearance would be about the same or not but I replaced the water pump in my Super 88 diesel in spring and didn't remove the radiator.
