Got my clutch in my Cockshutt 1550, & got the power steering hooked up, works fine, BUT, When I try to shift gears, it is really hard to take out of a gear * change gears or put it into neutral.. The gear shift goes all the way up to the dashboard. A couple of times it felt as it went into 2 gears at once as it wanted to kill the motor. When I bought the tractor I knew the clutch was gone on it, When we took it apart the release bearing was seized solid, & wore the fingers on the pressure plate way down. The guy I bought the tractor from was probably ramming the gear shift lever to get it into & out of a gear. As I was trying to get it out of a gear now..
Is it possible that the gear shift lever is bent, or??? under the plate ??
The gear shift is real loose & swings quite a bit even in gear.
Thanks in advance..
Thanks in advance..
