1800 c hydraulic
blake D
The remotes have been changed to pioneer and the issue is I cannot relieve pressure to hook or unhook lines even when the tractor is off
Also when hauling the dump trailer on the three point the weight makes the three point fall but it bypasses and raises the dump box
You said: The remotes have been changed to pioneer and the issue is I cannot uncouple them. That is because there are check valves inside the remote valve housing. The spools are not selective fit. You will need to update your couplers to a newer version. I don't understand part 2. Will the 3 point hold any other load? Is there a remote cylinder to dump the unit? If so is it single or double acting?
Couplers on tractor are pioneer ends and the implement is pioneer even if I relieve pressure on the implement and shut the tractor off and shake the levers the tractor still has pressure
And for the dump trailer it is the only thing that has been on the three point since we had it it is a single acting cylinder power up gravity down
You can shake those levers all day!. That will not move the check valves off their seats. Now on the 3 point and the single acting cylinder. I don't know anything about your set-up but you need bleed the 3 point off so you can run a one way cylinder. I take it you do not have an operators manual. You have e-mail?
Blake that was the nature of the 1 I had. Someone before me put a T in the lines just before the hydraulic coupler so you could bleed some pressure off. Always got hyd oil all over me and everything else. that is the reason I traded it off for a 200AC.
