Oliver 1550 Gas
I do know it will bolt into the frame,bell ,clutch and flywheel should work on the motor.Only thing different I think is the 880 motor is a 1/2'' longer in the back and you can get around that with the PTO shaft and the hollow imput shaft.I put a 880 motor in a 770 and made it work fine.
