88 hydraulics and a 1 way cylinder
super99
I would like to run my auger with my 88, but it has a 1 way cylinder on it. Don't you have to have a special fitting on the pipe coming out of the hydraulic unit to run a 1 way cylinder on a 88? Thanks, Chris
My 880 hydraulics won't lift my 10 inch 70 foot auger. Not enough pressure. Also those cylinders will take more oil than your reservoir will hold unless you have an auxiliary tank. I like using the 880 on the auger but I have to use a different tractor to set the auger up to the bin.
Thanks, I have a Westfield 8X60 with swing hopper. None of my tractors will pick it up from the totally lower position, have to help it with the loader for about 3 ', then the tractor can pick it up. I used it on a JD 70 last year, but it is a major pain to get auger set to bin with the hand clutch. Thanks again, Chris
