1600 governor
Well I am overhauling the engine in my 1600 utility.I did not notice when I removed the governor that I had an extra part. Hopefully I can post the pictures. One of the washers had a make and part number on it. AETNA F2. I looked it up on google and it is a good complete thrust bearing. The governor seamed to work ok before. Anyone seen this done before? They just stacked this complete bearing on the first washer of the original bearing.
Governor pictures
Where is your K-289 thrust washer? I am not sure I understand the question about the thrust bearing. You should have 3 pieces and they slide on the spool. How much wear in the pivot pins and weights? You have a parts book?
