Got my 1555 running, what oil?
bv
My 1555 is running now can you tell me what oil you guys use in your tractors, engine, trans, hydra power, and what ever else, thanks again.
Engine-gas= 10w30
diesel= 15w40
trans/rearend= 80/90w gear lube
hydrapower= universal trans/hydraulic
some use ATF
hydraulic= universal trans/hydraulic
Don't be putting around with it! We use Deere's break-in oil for at least the first 20 hours. Keep at least a 40 Horse power load on it for the first 20 hours too. Why Deere's oil? We got a deal on the old stock item, about 1/2 price of the new number.
Also since it did not run before once you get it warmed u good after running it for about a good half hour at operating temperature, retorque the head reset he valves and if you have any leaks stop them. Remember that transmission oil level goes to the top of the pipe nipple.
Ok thanks J. Did you get the pump numbers I emailed you? you were going to get the correct timing settings for that pump, thanks again to you guys.
