I have a new to me 1650, I believe it's a 1967.
I cannot lift a 1500 bale of hay, it feels like the hydraulics to lift are restricted in some way.
The tilt for the loader has enough power to lift a bales weight, but the loader lift cannot.
I have read for hours posts relating to this, and now am at wits end.
I have adjusted the restrictor valve out, and played with it to no avail.
I have cleaned the filter or element.
Filled with ATF fluid, the hydraulic fluid was low initially.
I spray washed the tractor and cannot find any leaks in the hydraulics.
I have tried to locate the hydraulic relief valve, but am not able to find it, googling it or otherwise.
I am thinking according to my research so far that I will try and locate, clean screen etcetera for the relief valve if someone can point me in the right direction.
Maybe it is sticking??
I'm sure there is information I am missing please keep in mind I am not mechanically inclined, but I do my best.
So idiot proof directions would be needed..
Any help certainly would be appreciated, bought tractor to put 1500lb hay bales out for horses.
Hopefully someone can help, tired and frustrated.
