OK got my tractor home runs good. I think he said it's a 1967. I can put it in gear, then start it & it goes but nothing on the pedal. If I push on the clutch pedal it makes a bit of a grinding noise. tried to set it up for an inch or so free play. but still nothing when I step on the clutch. Tractor keeps going. Have to turn ignition key off to stop it.
Could it be the clutch release bearing? or the yoke the holds the bearing?
Any and all suggestions welcome.. And it has hydra power & that works good when It's going, shifts in & out fine. This is my first Cockshutt so I'm in strange territory.
thanks in advance
thanks in advance
