chucksoliver77
test
Does that half ton handle that trailer and tractor ok? How much weight do you have on the truck in this picture?
(quoted from post at 21:25:52 09/24/14) Does that half ton handle that trailer and tractor ok? How much weight do you have on the truck in this picture?
Shim, The tractor and plow weigh about 7000lbs. The truck has a rated payload of 3060 lbs. which is more than my brother 2002 2500 dodge with the cummins. It has the 3.5 V6 ecoboost engine and pulls and handles it very good. Chuck
Shim, The tractor and plow weigh about 7000lbs. The truck has a rated payload of 3060 lbs. which is more than my brother 2002 2500 dodge with the cummins. It has the 3.5 V6 ecoboost engine with a gvw of 8200 and pulls and handles it very good. Chuck
