1655 Clutch replacement
pd143
New User
I am going to start the the clutch replacement on my 1655. I would like some input into what else could use checking or replacement once the engine is out. Thanks
Always a good idea to do the rear main seal. There are several clutches available. I put a heavy duty 6 pad clutch in mine.
Josh
Coupling chain and sprockets. DO NOT use the cotters from the coupling chain over again.
Among the other stuff mentioned, check the spline wear on the end of the pto drive shaft and the hub/plate that drives it. Other seals to check: front and rear on 2 or 3 speed, if equipped, and the trans input shaft.
