Oliver Super 66 Question.
DCW
I have one of these and have no information on it.What is the specs for compression.I suspect this one has valve troubles,but I have nothing on it.Thanks.
You don't actually need the specs - just compare the compression results for each of the pots. Ideally, they should all be less than about ten percent spread. The best will give you some idea of what the rest should be.
RABL
