Cockshutt 30
Chris5
How light can you get a Cockshutt 30/Co-op E3 for pulling with a high low? Are they a competitive puller in the 3500/4500 dead weight? Have a lot of Farmall C's and Super C's and a few 66's to compete against in the 3500 here.
I have mine down to 3500 with me (160lbs). Its all stock wheels and tires, front mid and rear weight brackets, probably at least a couple hundred lbs of brackets. Only things removed are the fenders, hydrolics and pto. As to how well it will do, haven't been able to test mine, both times I've had it out this yr it has broke, first the condensor, and now a broken valve spring. But my inlaws claim they used to dominate the local 3750lbs class when they pulled a 30. I did do very well with it in transfer pulls last summer though.
