2150 fender fuel tanks
I need a pair of front light covers for the fender fuel tanks for a 2150. The part #'s are 164132-A and 164134-A. I had a cab on the tractor so the light covers were blank. Anyone have a pair or know where I can get a pair. Thanks Larry
Larry it will not be original but you can get light washers off a set of regular oliver fenders which have the correct bowl shape and correct diameter.Lay out your light location and get a hole saw the diameter of the light washer drill and weld light washers from back side.Make sure washers are flush on front. Tig or mig welding will work better for the sheet metal.
You can use a hole saw to cut the hole where the light belongs, and then use a dimple die to make the bowl shape for the light body to sit in.
