What engines fit a 2-85 or 105 White?
Alan K
Might have spotted a White tractor, not sure if it is a 2-85 or a 2-105 or exactly what is wrong with it. Im wondering what engines will fit it without too much modification. Did they use the same engines in the Massey combines? Thank you.
Thank you for the info. Did both the 2-85 and the 2-105s use the same motor but different injection pumps to gain the extra hp on the 105s?
Probably one little change is top ring in the piston kind of V shaped a little when you look at the end of the ring in the turboed engines.
Not sure how important that is.
It is a 105. Supposedly has a lot of blow by. Someone had told them it might be a piston. How much is required to replace the motor with one from a combine?
As long as you have the tractor motor too,it's not bad. You pretty much have to strip the combine motor to the bare block and head,then put all the tractor parts on it.
You need tocheck that out better. Most 2-105 tractors had a354 dot 1 engine, late ones had a 354 dot 4 engine. I also sent you an e-mail. Did you receive it? J.
Yes I did receive your email. Thank you. Been in and out and haven't had much time on the computer or home enough to call. What is the difference between the dot 1 and dot 4 engines? Im not sure what year the tractor is, does have headlights in the grill and I remember a "WHITE" decal or plate on the upper right side of the motor.
