Cockshutt 50 diesel starter/generator
I have a Co-op E5 Diesel and Cockshutt 50 Diesel I am looking to restore. Took the starter and Generator to the repair place I normally take them and he said he can't get parts. So, I am looking for a good rebuilt starter/generator for one of these. Thanks for any help.
Can't your repair shop set down and find someting newer that will fit. I have a Cockshutt 40 with the Perkins L4 engine. The starter went bad and they couldn't get parts for it. So we checked the starter drive and found out that the drive and bendix of a IH 1206 was the same. The only thing they had to change was the direction that the srarter turned.
Before you get carried away and I am going by memory but a 50 is an Auto-Lite system Your 40 with the L-4 is a Delco in this country and so is the IH. Now where are you located and what parts do you need? Do you have a phone number or -email? J.
I believe I have two or three rebuilt 50 diesel starters. I am away from home until Wednesday. If you are interested send me your phone number.
Starters and Generators:..........when your shop
says that they "Can"t get parts anymore" It
means that they aren"t interested in fixing your
stuff....it"s time to look for a different repair
shop !!!!!!!!!!!
We didn't put the guts in we put a rebuilt 1206 starter that they had rewired to turn in reverse of what a 1206 starter turns.
The starter we replaced it with is for Ih 1206 and is a Delco Series 35 MT , Model 1113402, 12 volt, Rotation CW.
