supper55 pto
My late model 55 PTO just quit working, the lever to engage has moved forward 6 to 10 inches, after looking into the belly peephole, I found the whole clutch pack has slid aheadê or 4 inches on the shaft,is there some sort of snapring or rollpin that holds the pack in the right position on the shaft, thanks, rod
The clutch pak is held in place with a 2 piece set screw---The main set screw locks into the shaft & the 2nd locks it in---HTH
Kent Gordon
Palestine, Tx
