Jake Collie
I think it's a good idea for me to change all the fluids on my new-to-me 1850. The book shows 10w30 engine oil above 32 degrees and 10w below 32 degrees. Trans and final drive shows SAE 80. Hydraulics show SAE 10w or ATF type A. Over/under hydraul-shift shows ATF type A.
I'm thinking about 15w40 for engine oil, hytran for trans & final drive and hydraulics, and maybe hytran for over/under. I guess ATF type A is OK too for the over/under but I think I read somewhere that White changed the spec to hytran. What do most of you guys use?
