Using my Super 55 this last Labor day and everything was working great. Then I hear the clutch pedal drop onto the tool box cover and realize I have no pedal. Shut it off right then and there. I then looked over the issue and realized I had broken the linkage from the pedal to the clutch arm. I looked over how everything was mounted and realized I had missing parts. I went over the ground and found two parts. However I am not sure I have all of them. I disassembled the parts left on the pedal and assembled them as I think they went back together. The part off the pedal looks to have been broken once and another bolt welded to the side of it. The bolt goes through a swivel of sorts that connects the pedal to the lower arm. The bolt that was welded on and the original area I can see is 1/4" or 3/8" but the hole in the swivel is like 5/8". Is it to be that way? Am I missing something? Parts? What to do. I have attached two pictures hope they are here. If not I"ll try again. Any idea on a repair and if there are any missing parts I need?
