I know a lot of these conversions have been done, but there doesn"t seem to be a ton of info or detailed parts lists out there on how to get a project like this going.
I have an 1855 with a non-cooler block 310 that has started mixing oil and coolant. I wouldn"t have a problem with having the 310 rebuilt, but worry that it won"t perform in the 110-120 horse range reliably like I"d like the tractor to in the future. Would mostly be using the tractor to pull a 13" NH7450 discbine, and we do have some hilly ground.
I"m pretty clear on needing an sae3 bellhousing, 100 series white clutch/flywheel and different pto hub, but I know there are a lot of other details.
Any industrial 5.9 cummins should have the proper manifolds and pump?
Can the 1855 tub be easily modified to accept a 5.9, or is an 1850 diesel tub a better option? If the 1850 tub is used, do the 1855 steering box and front end interchange?
Any input I can get from you guys would be appreciated
