super99
I had picked up filters for the 2-62 at Napa. I drained the engine oil today and went to change the filter. The new filter ( Napa 1050 ) only has one small hole in the middle( maybe 1/8th" ) and 2 of the same size holes in the outer part of the base( hope the picture comes thru). The old filter looks like a normal spin on filter, large hole in the middle and holes all around the outside. No way can this filter allow enough oil thru it to work. I put the old filter back onto it until I can go back and make sure the filter is right. Guess I won't be starting it until I get the right filter.
I am going to change the oil in the Reverse o torque, the book says to drain the converter and the unit. Then to put 1 1/2 gallon of oil in and run for a few minutes and then add the last gallon. Not familiar with torque converters, does running it refill the converter? Chris
