oliver model 82
Jpott62
New User
Hoping someone can help me out. I have just gotten my grandfathers oliver model 82 sickle mower up and running again after 35 years. It was cutting hay like a champ then started slipping the clutch all the time. The spring that puts tension on the clutch is broken. Anyone know where I can find one?
I might have one, I will check. I am headed to Madison SD for the national Oliver show. Not knowing where you are I will take a chance and bring it along. Look me up at the CSHPOCA booth.
Thanks
John Schoenauer
I"m located in michigan, would love to get this
mower up and running again. Any idea where I could
find seals for the pto input and pitman output? You
can call me 517-231-2420
If there is enough seal left take it to a good auto supply store they can measure it and find a replacement if the seal is mostly gone you will have to measure the outside of the hole the seal fits in and the outside of the shaft. I tried having the Oliver seal number cross referenced and that seal would not fit.
Thanks
John
