super99
BUMMER!!! I tried to take the brakes apart on the 2-62 (1550) this evening. The loader frame is very close the the brake housing. I took the lower bolt out, there was a hole in the loader frame for the bolt to go into to remove it. Started on the top bolt, it comes out against the loader frame and stops several inches for coming out. The rear bolt is in the open, no problem getting it out. Someone welded the loader frame to the rear axle, so it isn't coming off even if I had enough jacks and blocks to try to take it off. Anyone ever done brakes on one of these with a loader and backhoe on it? I'm wondering it I took the platform off if I could leave the top bolt in and turn the outside cover to the top and get the brakes apart that way? I think the seal is leaking on this one, everything outside is soaked with oil. Also, there is no transmission filter on this tractor, did the industrials not have a filter on the rear end?
This computer isn't letting me upload pictures tonite. If someone want to post them, I'll e-mail them to you.
