single acting cylinder with an 880
pvia
New User
What do you have to do to an 880 hydraulic system to use a single acting wagon hoist cylinder.
Thank you, Phil
One it needs to run off of the left side if you have a double unit. Most likely you will need a supplemental reservoir to increase the oil capacity. You will need a third hose and a supplemental momentary restrictor. Do you have an operators manual
